oil conversion to gas
jagirl57
Member Posts: 1
I am planning on changing from oil to gas . I have gotten various pricing estimate and the same for different types of boilers. I would like a the best possible boiler without paying and outlandish price. i have heard about - crown, utica, new yorker, slant what is your views on these ? thanks
What do you have
for a system now and what Make and Model of boiler?
Has a heat loss been done on the house?
Have you installed insulation or new windows or any other energy saving procedures?
More important than what make of equipment is the installer who will do the work. Make sure they are doing a heat loss on the house or if steam a measurement of existing radiation. Will they do a combustion test upon completion of the installation. Will they service the unit after it is installed.
A lot of the new Modulating/Condensing equipment requires annual service and in some cases cleaning. Is your contractor going to offer to do those services.
Get some references of previous work the contractor has done and check them out with the BBB.0 -
Steam or Hot Water?
Is your present system steam or Hot Water?
- Rod0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
