Navien CH-240 ASME Outdoor reset Connection
vicpj1
vicpj1 Member Posts: 4
HI, I have a Navien CH-240 ASME and I'm trying to install the outdoor temp sensor. I bought the sensor pt. # NASS9EXOS001 but it didn't come with a cable.I thought I could connect thermostat wire right to the circuit board, but there is a small 2 pin connector on the board. Has anyone installed one of these. Any advice would be greatly appreciated...   Thanks.. Victor in Swansea, Ma.
  • JStar
    JStar Member Posts: 2,752
    Sensor
    The wiring harness comes with the boiler. You may need to order that, too.
  • vicpj1
    wiring harness
    Jstar thanks for the reply. I have searched on-line for the harness, but can't find anything. Is that something i need to order from Navien...
  • JohnHenry_2
    JohnHenry_2 Member Posts: 70
    The connector
    The pigtail connector comes with the unit. It has blue wire on mine. If it didn't come with the unit, call Navien and have them send you one.
  • vicpj1
    wiring harness
    I called Navien, they are sending me the wire with the molex connector free of charge.   thanks for the replies....
  • JohnHenry_2
    If you're working on your own system
    You might want to have them send you a service manual if you don't already have one. The I & O manuals come with the unit and are available online but the service manual seems to have to come directly from Navien.
    I've found their support to be excellent.
  • vicpj1
    Service Manual
    Heres a link for the service manual
    bostonheatingsupply.com/Navien/CH%20Service%20Manual.pdf
