trouble wiring pump control
boiler_man
Member Posts: 21
I recently purchased a DPC-CLL dumpexing pump control from "DWYER". I and 2 electricians have been scratching our heads for many hours at this control trying to understand how to wire it in. I have tried to attach the only wiring diagram that came with the control.
The switch is to control and alternate 2 condensate return pumps to a steam boiler. The boiler has a float switch that sends 220 directly to the pumps. Id like to install this control between the float switch and the pumps so that it will alternate them.
Any light that can be shed on this matter is appreciated.
Nothing attached.
Nothing attached. Does this control have a time clock or is it used as "Lead/Lag".?
Mike T.0 -
thank you empire
dpc control
It is a lead / lag0 -
You
want to use the float switch as the control switch in that diagram,and let the new controller direct the 240. http://www.dwyer-inst.com/PDF_files/DPC_iom.pdf0
- 125 Chimneys & Flues
