yet another, What is this?
Slimpickins
Slimpickins Member Posts: 359
This is the top level (2 story) of a house built in the early 1900's in Denver's Congress Park neighborhood. It's a 2 pipe system with a 12 year old Burnham cast iron and with original rads. What the heck is it?
  • Zman
    Zman Member Posts: 7,611
    Funny place for a shower!
    I believe there was an expansion tank and the attic and the device you see helped maintain the correct level. There is a similar device in one in one of Dan's books, "how come"? There are not many "live men" that know how to operate that!
    Albert Einstein
    Steamhead Member Posts: 18,205
    That's a Honeywell Heat Generator
    or another, similar brand, which allowed the pressure to rise enough so the water in that system could run hotter than the usual 180° F. It discharges into the expansion tank, which is above the ceiling.
    If you take that out, be VERY careful since the lower part is filled with mercury.
    Consulting
  • alotlikeearl
    alotlikeearl Member Posts: 68
    Apparently it holds a lot of mercury!
    Hope this link shows up.
  • alotlikeearl
    Goofed
    Link did not work so here is part of data.  25 to 30 lbs, thats a lot!
    HONEYWELL HEAT GENERATORS
    If a Honeywell heat generator is encountered in a home and needs to be removed, it should be removed in a manner that ensures no mercury is released from the unit.  These units generally hold between 25 and 30 pounds of mercury.
    First, remove the unit from the home intact, as seen in the photo below. Then place the unit into a large plastic bag, always keeping the unit in a vertical position.  Take the unit to your local household hazardous waste facility or hire a professional environmental consulting company, both of which have trained personnel who can handle and dispose of mercury appropriately.
    Mercury Honeywell Heat Generators
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Not that I've ever seen...
    The most I've ever gotten out of these devices was a baby food jars worth. Maybe 5 pounds worth.
    ME
  • alotlikeearl
    Shocked!
    I am shocked that the EPA would have false info in their data.  Oh no, now my tongue is stuck in my cheek!
                            Jerry
  • Mark Eatherton
    Me too....
    See... ;-/)
    ME
