parts type used with CI baseboard
heatingFun
heatingFun Member Posts: 84
which type of parts I should use to directly connect with CI baseboard, cast brass, copper, galvanized, or black steel? I am thinking it may make difference because of the different expansion rate.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,515
    what ever you want
    Where you will find expansion problems is the run to the baseboard . The connections do not matter .. Least to most iron ,brass , copper ,pex
