KKH-14
Bostick84
Member Posts: 1
I have an old heater, model #KKH-14 and I need to know what the BTU's are on it so I can replace the unit with a new model of similar size. Any help out there? Thank you!
Someone professional may have the answer to your question.
Let me suggest, however, that a better solution if you have a hot water system is to calculate the heat loss of your building and from that, determine the size of the boiler you need. If you have a steam system, calculate your radiation and from that, determine the size of the boiler you will need.
When I got a new boiler, my old one had a Beckett oil burner in it rated at 70,000 BTU/hour. I could use larger nozzles to increase the firing rate, but never did that. When I calculated the heat loss of my house, I got 30,000 BTU/hour. A 70,000 unit would be over twice the size I needed.
I had to settle for an 80,000 boiler anyway because that was the smallest boiler my installing contractor had to offer of the mod-con type.0 -
Bad news...
http://www.heatinghelp.com/forum-thread/64663/Hydronic-Heater-Unknown-Make#p746576
Looks like its time for a new toe kick space heater...
ME0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
