Rheem oil fired scorched air furnace. Inconsistent blower operation .
helpingothershelpthemselves_2
Member Posts: 326
in Oil Heating
helpingothershelpthemselves needs help .
Rheem oil fired scorched air highboy up-flow furnace. Approximately three years old.
Blower operation extremely inconsistent.
Unit utilizes Honeywell fan outboard logic control for blower timing operation . OEM Rheem # 47-102686-01
Replacement of fan controller proved useless. Timing changes to controller also proved useless.
Not the normal customer complaint of blower running too long after cycle , but complaint of blower on too early as well as blower on too long after run cycle.
Have we seen any issues regarding this ? Possibly a revision level in circuit board ?
Thanks,
Ken Resnick
Thanks,
Ken Resnick
Fault found
Manufacturers A/C ready kit relay found to be the culprit.There was an error rendering this rich post.
