Accidentally Cut Threads
bowman
Member Posts: 20
I had to remove a piece of pipe from a fitting in a one-pipe steam system and it wouldn't budge so I cut it off next to the fitting and cut into the remaining stub of the pipe inside the fitting in three places and then chiseled the old pieces out. Done this many times before with no problems but this time I accidentally cut too deep and one of my cuts ended up going all the way through the threads inside the fitting I am trying to save.
I don't want to replace that fitting too, so I am wondering if I can fix this by epoxying a nipple in the damaged fitting with JB Weld. It is residential steam operating at under 2 PSI, but the damaged area is also low so condensate will be flowing past it as well.
Will JB Weld work? Is there any other product that I can try? I recognize that such products may render the nipple impossible to remove in the future but that is probably not a problem given its location. At this point replacing the damaged fitting would be more problematic, especially if JB Weld or something similar could do the trick.
Any thoughts?
Any thoughts?
Cut Threads
Hi- If it's just the threads cut a bit, I'd use either some high temp silicone or just wrap it with teflon tape and use some pipe dope and tighten it up. I've done a couple like that and didn't have a problem.
- Rod0 -
ditto
blue teflon tape and high temp caulk. Install and sleep easy.0 -
Damaged Threads:
Three or more wraps of Blue Monster Teflon Tape and #5 Rectumseal on the male and female threads.
I've never ever had a leak in the years I've been doing it.
I'd skip the JB Weld. Eposy and heat do not go together. My high school autto shop teacher had a saying, "You can't buy a mechanic in a can.". In 50+ years, he hasn't been proven wrong, yet.0 -
black high temp
permatex gasket sealer on both the male and female threads..screw together and you'll be fine..gwgillplumbingandheating.com
Fixing a boo-boo
Don't forget to pay attention to the pressure your repaired joint may have to hold, and keep it down!--nbc0 -
Thank you
Okay. Thanks everyone. I feel better now knowing that I can salvage this screw up. I will go with a non-epoxy product and next time I will be more careful when cutting inside the threads..0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
