Hydro Therm hc100
Hi the above boiler continues to flame out. I have already change the two-wire generator. It lights and runs for a short time and then goes out. This has happened about 6 times in the last 24 hours. Any idea what is wrong.
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    When you say generator
    I assume you are talking about a powerpile self generating systems is that correct? If so go to the top of this section and click RESOURCES then click LIBRARY and look for Tim's Closet there is a troubleshooting procedure for powerpile there along with the charts to diagnose your readings. Or you can call a pro and have them go through it. If the tech is not familiar with these systems he can contact me at gastc@cox.net or call 401-437-0557.
