Identify This Annoying Sound
Jimmbo
Jimmbo Member Posts: 39
My radiator is making a godawful racket every time the heat comes up. Can anyone figure out what's going on? It's an older house, so there are various random steam sounds, but none as persistent as this one. <a href="http://www.hark.com/clips/lcfjjfygkg-steam-sounds">Listen Here</a> (give it about 15 secs to load).
In the attached photo of the culprit, the valve at lower right was installed a few months ago, so it's pretty new.
Thanks for any help. This radiator's right next to the desk I try to write at. Argh......
    Jamie Hall Member Posts: 26,707
    Got kind of a nice jazzy beat...
    but you need some strings or horns in there...
    More seriously, did it do this before the valve was in there?  It doesn't sound like a classic hammer, nor like a classic expansion noise, but if one knew it was related in some way to the valve... is the valve open all the way?
  • Jimmbo
    An Elvin Jones Gig That Never Ends
    Yeah, it's got sort of an Elvin Jones polyrhythmic vibe. But the problem is I can't turn the record off. Like...ever.
    SHOULD the valve be open all the way? I'm afraid to touch it. Because I am an idiot. And idiots learn not to touch stuff like valves unless explicitly directed.
  • Rod
    Rod Posts: 2,067
    Steam Collapsing
    Hi-  The noise you are hearing is steam collapsing when it comes in contact with cooler water. The valve needs to be fully open  (turn counterclock wise) otherwise the incoming steam and outgoing condensate (water) collide.  Also check the slope of the radiator with a carpenter's bubble level.  It should be slightly sloped towards the intake valve. I use quarters ($0.25) under the radiator's feet at the opposite end from the valve to raise and slope the radiator. It just has to be enough slope to "encourage" the condensate to flow out of the radiator . Too much slope can cause problems.  Try opening the valve all the way and making sure the radiator is sloped and let us know how that works out.
    - Rod
  • Jimmbo
    Steamed Me
    Thanks. It was half open. If I recall, the thinking was that this is an awfully small room, and my desk is right near the radiator. Which I guess was smart thinking, because the temperature in the room is always about right. But.....then there's the noise!
    But I just did open it all the way. I'll see how that goes....and will also check slope a little later and report back.
    Thanks again!
  • Rod
    Rod Posts: 2,067
    TRVs
    Hi-  If you have a problem with the room being too warm you can install what is know as a TRV (Thermostatic Radiator Valve) on the radiator. On a one pipe steam system the TRV goes between the radiator and the radiator vent. It can be set to the temperature you desire and will stop the radiator from overheating the room,  Here's a link with some information on it -      http://www.heatinghelp.com/files/posts/8569/TRVs.pdf
    - Rod
  • Jimmbo
    Thanks!
    Thanks! What an awesome forum! You guys are fantastic!
    I can feel my migraine reducing already.....
  • Jimmbo
    Radiator Covers
    One follow-up. Do big boxy wooden decorative radiator covers present any problems? I generally pull them a few inches out in winter to let the heat out. But I'm planning on leaving this one flush with the wall because, with the valve fully open, heat shouldn't be a problem in this room. Is there any downside to that?
  • Rod
    Rod Posts: 2,067
    Book on Steam Heating
    The cover shouldn't be a problem as long as you're getting enough heat in the room.
    if you're new to steam,  you might want to check out the "Shop" section of this website as there are a lot of good books there on residential steam heating. I'd recommend  a book called "We Got Steam Heat!"
    http://www.heatinghelp.com/products/Steam-Heating-Books/25/61/We-Got-Steam-Heat-A-Homeowners-Guide-to-Peaceful-Coexistence
     It's written for the homeowner new to steam heating, It's easy humorous reading and is filled with diagrams and pictures.. An evening or two of reading will put you light years ahead in your knowledge of residential steam heating and the knowledge it gives you will save you money.
    - Rod
  • Jimmbo
    edited February 2012
    Book Order
    Thanks. I'll order the book right now.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    One note on the radiator
    with the current location of the air vent the radiator is not working with a full usable volume of steam. This may have been done on purpose since it is a small room. The steam will short circuit across the top to the vent and close it before all the air is vented out. Glad your migraine is gone. As for covers they can reduce or increase the output of the radiator. If you do a search on "The Wall" there are many threads about them. I recommend against their use in general.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • RJ_4
    RJ_4 Member Posts: 484
    Danfoss auto vents for 1 pipe systems
    Be careful using auto control steam vents. Boiler must cycle alot during the day and pressure in system needs to drop way below air vent drop away press for radiators to shut off.
  • ChrisJ
    ChrisJ Member Posts: 17,042
    overheating?
    Before any drastic expensive measures such as a TRV I would try a simple Gorton #4 vent.  This may cure all of your overheating problems.
