Matching Boiler to Radiators EDR - How Close Can It Be
Peter D
Member Posts: 7
Hi everybody I'm looking to do a boiler replacement.
My current EDR conected load is 355 The boiler is rated at 350. The steam pipes are very well insulated 2" thick fiberglasswall. Question is, can I go ahead and go with this boiler since it's close to a match? A couple heating plumbers think it will be ok. Thinking I can go with a 1.315 pick-up factor. If I go up in boiler size it will be 412 EDR. Has anyone out there put a boiler in that comes this close to the load? Any issues or not? Just want to get it right. Or am I just fretting over nothing?
Thanks all, Pete
Thanks all, Pete
350 is a winner!
Get the 350, the pick up factor is allready built in. Which make and model are you thinking about getting?0 -
thats
about as close as it ever gets!gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 114 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
