Matching Boiler to Radiators EDR - How Close Can It Be
Peter D
Member Posts: 7
Hi everybody I'm looking to do a boiler replacement.
My current EDR conected load is 355 The boiler is rated at 350. The steam pipes are very well insulated 2" thick fiberglasswall. Question is, can I go ahead and go with this boiler since it's close to a match? A couple heating plumbers think it will be ok. Thinking I can go with a 1.315 pick-up factor. If I go up in boiler size it will be 412 EDR. Has anyone out there put a boiler in that comes this close to the load? Any issues or not? Just want to get it right. Or am I just fretting over nothing?
Thanks all, Pete
Thanks all, Pete
350 is a winner!
Get the 350, the pick up factor is allready built in. Which make and model are you thinking about getting?0 -
thats
about as close as it ever gets!gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
