Is this vent CPVC?
Kestrel
Member Posts: 102
This is a Lochinvar WHN085. I purchased 2" CPVC to do the vent and air intake, and it's quite a different color than I expected.
The material I bought from the supply house is a light beige. The vent on the boiler (pictured below behind the pressure relief valve) is a much darker gray. Are they both CPVC?
Unfortunately I realized this after hours on Friday, and I'm hoping not to have to wait until Lochinvar tech service opens on Monday!
wrong stuff
Sounds like you got Cresline Flow Guard Gold which is smaller diameter than the gray CPVC. It's used for hot and cold water piping. I ordered CPVC from a supply house for will call and went to pick it up and thats what they had for me. I've learned since, you need to specify that you're using it for venting a boiler.0 -
Dang
I did - I did tell them exactly what it was for.
Is there a specific designation for the darker gray stuff for flue venting?0 -
Check the ASTM numbers....
In the installation manual, it clearly states the ASTM requirements and approval numbers for using different plastics. If the FlowGuard meets those standards, then it is safe to use. If not, return it and make sure they give you the right stuff. ALso make sure the primer and cements you use are also in compliance with the manufacturers requirements. Not all cements and or primers are the same.
ME0 -
Flowguard does not meet the standard.
As previously posted you need CPVC. I use Sch 80 CPVC. It is grey in color and meets the ASTM standard.0 -
Glue
I wasnt aware there was a rating on glue and primer.
Where on the glue does it state ASTM rating?:NYplumber:0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
