squeeling oil burner??
ChrisJ
in Oil Heating
Hey,
I'm posting this a few days after seeing the actual burner. A friend of mine has a WM hot water boiler. I *think* its a WGO gold series boiler with a Beckett burner. Problem is I cannot remember what model burner it was other than it is NOT an AFG.
Burner seemed to run good but kept squeeling occasionally. the squeel had a very metallic sound to it. To me it sounded like a bearing issue but I know close to nothing about these burners. Is this a sign of a soon to come failure? Is there any preventitive maintaince that should be done?
sounds
like something is in need of attention (squeaky wheel get's the grease) I would identify the part and find a solution to it before the unit shut's down when most needed....0 -
sounds like
a bad PSC motor to me0 -
Squealers:
It's the Pig Iron in the motor.0 -
clogged pump strainer
sounds like a clogged pump strainer to me,a lot of do it your self do not even know the pump have a strainer.0 -
clogged
And/or a clogged canister filter.0 -
That was my second thought
but it would be coughing after a few seconds of a major pump whine. Is there a rumble or stutter when it is squealing?0 -
squeeling
No other noticeable sounds other than the squealing.
To me it sounds like a bearing or bushing ready to go.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Squealers:
More like Vacuum Whine caused by high vacuum in the fuel pump. Usually caused by a clogged filter or pump strainer. If any of the above, will next cause the nozzle strainer to be restricted and loose pressure at the nozzle tip. Causing smoke and soot. Then shut downs.
You need to call a professional and have it serviced. If you had to ask what the noise is, you do not have an understanding of the process or the experience and skill to resolve it. There is no "Universal Nozzle" to use. It must be an exact replacement. It needs to combustion tested.
Anyone of the techs who have responded here to you would know what to do within a moment of hearing it. What sounds like a noise to you, has a cause and remedy to us.
Call a Professional.0 -
Don't have the skill?? Seriously?
Icesailor perhaps I'm reading your post wrong but I find it insulting. You essentially said I don't have the skill to change fuel filters or replace a nozzle with an exact replacement.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I wouldn't
take that offensively Chris. Although we give you some reference to resolving an issue, I personally would not like to see or hear of advice gone bad. It's always best to get a pro, but I do see many here asking questions because they are paying top dollar to "pro's" and are still having problems. There is 2 sides as always. Good luck, and let us know how you make out0 -
Bill
I have no doubt someone who knows what they are doing should look at it.
Whether I have all the skill in the world still doesn't change the fact I don't have the tools to do a combustion analysis. I also realize someone who works on these constantly will know what causes a sound or a problem immediately as they have seen it a hundred times.
As you may know I also had a very bad experience with a "pro" which almost killed my family due to a plugged chimney. The really bad part is I specifically asked him to check the stack draft. I now have my own manometer.
I just found icesailors post insulting. Maybe its simply how I read it, sometimes things come across completely wrong via text.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I can't blame you Chris
and I'm sorry to hear of a near fatality. I think that the testing is the key, and that is what was stressed mainly I think. Kudos to you for wanting to remedy a situation. It is a tough position for us. We want to help steer people in the right direction, but we gotta be tactful on how and who we give info to. In your case, changing a possible motor shouldn't be too bad, just shut off all power to the unit, and check to make sure that is is off.0 -
dirty oil lines
All could be clean up top but the oil lines to the tank may be dirty . Is the tank buired , 2 lines to burner or 1 line from basement tank?0 -
Squealing:
As a string goes along, the origonal post gets lost in translation and the responses can go astray. The first post spoke about a metallic whine or squeal. I replied that it must be the Pig Iron in the motor. Then it devolved into pumpos and filters and vacuum whine.
The discussion went astray. I never questioned your ability. I was questioning the ability of the unknown person who the discussion devolved to. Someone that had a vacuum whine from dirty filters. You weren't asking about filters Someone else was.0 -
icesailor
Understood. I had a feeling I was simply misinterpreting what you had said.
Tank is in the basement with a single line. I'm sure hes going to have someone come look at it I just wanted to give him an idea of what to expect. For example a simple tune up or a big bill.
After installing my boiler a month ago I have ZERO interest of doing any work on any boiler ever again.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
