Remote CompressionTank
ChasMan
Member Posts: 474
I'm short on space for a larger compression tank. By my calculation I need 14 gallons (have 7). I can;t add another one so I was considering remoting them to the water closet. So, I would have the backflow / feed valve combo and twin 7 gallon tanks about 20 feet from the boiler. I would put a ball valve at the boiler for servicing. Does anyone see any problems with that arangement?
No Problem...
So long as they connect back to the system where the PONPC is upstream of the circ. and the interconnecting line is of sufficient size (you may want to use 3/4").Bob Boan
yes...
I do it all the time.... ok maybe not 25' from the ponpc... but 5'...kpc0 -
Great.
Ok, I will go ahead with this scheme. Thanks a lot.0
