gravity hot water heating
save
Member Posts: 1
I have a 100 yr old reinsulated apt. building in Amherst N.S.Canada with cast iron rad. a160000 btu oil fired N.Y. horzontal tube boiler Reillo f5 burner . I would lif to keep the gravity system as the burner is controled by a Tekmar 256 outdoor reset .My question is if i replace the steel i inch.pipe with 3/4 inch insulated pex oxegion barrier will i at least maintain the heat delivery.
Probably Not
If the system is still gravity and not forced flow, then the original pipe sizes must be retained. Have you considered putting a circulator on it?
Please read the attached article before making any changes.
http://www.heatinghelp.com/article/332/Gravity-Hot-Water-Heating/72/Gravity-Hot-Water-Heating-FAQBob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 428 Carbon Monoxide Awareness
- 114 Geothermal
