Oil and wood fueled boilers
TwoHandsPA
Member Posts: 1
In a previously installed system I am in the process of replacing the oil-fueled boiler which worked in tandem with a wood fueled boiler. The old system functioned but was inefficient and had air issues due to some leaks and a poor lay-out. Have removed the problem areas and am starting out with what the customer has supplied but have a design issue or two(to say the least) Have a diagram that I would like someone to check out before I make permanent. Will scan and send or fax.....anybody intrested in a puzzle?
Thanks,
J. Ambler
215-638-1315
Thanks,
J. Ambler
215-638-1315
Post it Here
And someone will take a shot at it.Bob Boan
Let's see it.
There are a lot of us that do and have done solid fuel and oil combo systems.
Most of them are smarter than me.
Try scanning it and posting it. That way we can put our heads together to help you find the solution.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
