pilot blow out
cceasy
cceasy Member Posts: 2
I have a very old gas furnace that sucks the pilot out on shut down intermittently, any suggestions. The furnace has a good steady pilot and the gas is set to 3.5"wc but it is like a whirlwind when the burner shuts down.
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    Are you a home owner
    or a technician? Check "Resources" above then "Library" then look for "Tim's Closet" for troubleshooting procedure.
  • cceasy
    pilot blow out
    a tech and thanks for your input
    Chuck
