owner
mrzhomeimp
mrzhomeimp Member Posts: 1
renovating old brick structure,single story above ground w/ 2 stories  below ground. Need to heat top floor which is one open space 20'w x 50'l x 12' h - 1200c/f w/ an enclosed room which is 12'w X 20l x 8'h located in center of floor against one wall'. heat is to be supplied by natural gas, forced air furnace from basement below or overhead, exposed duct - whichever is best. Also need to know what size furnace (btu's) and layout of trunk and supply vents if possible
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    The best thing to do for answers
    to your questions is to contact local HVAC contractors and have them give you some estimates and advice on what you need along with conducting a heat loss on your dwelling.
