recommendations
lchmb
Member Posts: 2,997
I have a friend who has a thermopride furnace. It's approximately 20 years old, burns about 600 gallons of oil a year and has been completely serviced every year for the last 8 by me. I see no indications of any problems with the HX. I had planned to upgrade the control, pump and burner motor this year just because of age. While servicing it, he mentioned maybe it's time to replace it. I'm not thinking it is needed due to condition but maybe it's not a bad idea to give it thought. I know Thermopride's are tough, but is there a "good age" to replace one? I dont like to spend someone's money unless it's a benifit to them...
Tom I have a friend of mine
who has a Thermopride 25 years now, he will not let me change it (wanted him to go gas). Still runs great and the local oil company services it every year and they give it an A +. One of the best warm air furnaces ever made by my estimation.0 -
Thanks Tim
I do agree it's an excellent system. I figured upgrading the controls would be a huge boost to the unit but just wanted to see other opinions. I like to be proactive but not sure it would be needed with this unit...0 -
Thermopride
That was why people invested in them, they last forever. Just keep an eye on the chamber. Most likely it has the 2 piece brick chamber, and will start to separate. Line or replace it if it has the potential to expose the heat exchanger. The older units were copper coated. Does it have the Beckett or Wayne? They are built like no other. I would consider a stack damper, experiment with pump pressures and smaller nozzles to increase the efficiency, but I would not replace it due to a number.0 -
Thanks Bill
It has the Beckett, the chamber looks like the day it was made and it's presently running 11% co2 45ppm co 375 stack. I do have a damper on it. I tinkered with the pump pressure/ nozzle size but honestly it runs pretty good by spec. Old saying, if it aint broke....:) thanks again..0 -
anytime my friend
I figured you had that set to squeeze every BTU out that it can. He may save more by having an energy audit done on the house itself. It may need some buttoning up. Outside air intake may also be of some help there0 -
hmm
Never thought of an air tube. Awsome idea!!0 -
should help
keep from pulling in the cold air from outside cooling off the house0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
