HousePex connectors
pipe4zen
Member Posts: 108
Looking at a job were homeowner installed HousePex . From there website it says its pexA.
I'm a Uponor guy, I would be connecting boiler, and tubing to manifolds. Can I use Uponor expansion fittings to connect?
Thanks in advance.
Thanks in advance.
HousePEX
I would call HousePEX for an answer. Uponor tubing is PEX A, but I can see why you want to make sure before you go stretching the stuff.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
