Gas-fired hot water heater, AOSmith - Temperature changes
Ritzy
Member Posts: 34
in Gas Heating
I am not knowledgeable about the workings of a water heater. I have an AOSmith, gas-fired hot water heater for 10 years...beyond the warranty date. The temperature of the water that this unit produced was always very warm. Now, the temperature of the water is becoming lukewarm. Does this mean that the water heater needs to be replaced? Is this a potentially dangerous situation?
It could be a number of things
including the age of the heater. The control could be out of calibration and may even need replaced. Based on the age of the heater it would be better to install a new heater than replace a control on an old heater.
Have you actually measured to see what the temperature of the water is? Someone could have changed the setting on the heater.
What area of the house did you note the drop in temp? If it was the shower it could also be the mixing valve on the shower. Another possibility is an open shut off on the washing machine and back feeding through the mixing control on the washing machine. Try shutting off the water hot and cold to the washing machine and see if it changes.
I would also recommend getting a professional plumbing and heating tech to take a look at it.0 -
Kitchen Water Temperature Cooler
Thank you, Tim. I noticed the temperature change initially on the 1st floor of a 3 story house. Then, I noticed it on the 2nd floor in the shower. The temperature knob was never moved...it is in its original position. As you suggested, I will have a plumber look at the heater. I appreciate all of your help, as always!0 -
future
If you do have it replaced, read the literature that comes with the new unit. Most recommend flushing the unit to keep sediment from building in the unit which can affect it's performance down the road...0 -
Yes and also
have the anode changed every other year and you will extend the life of the unit. My last two water heaters lasted about 20 years on one and 22 on the last one.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
