Flooded Boiler Information - U.S. Boiler Co. advisory press release
<a href="http://www.usboiler.net/assets/pdf/US%20Boiler%20Co%20Flooded%20Boiler%20Statement%20August%2029%202011.pdf">http://www.usboiler.net/assets/pdf/US%20Boiler%20Co%20Flooded%20Boiler%20Statement%20August%2029%202011.pdf</a>
U.S. Boiler Company, Inc.
P. O. Box 3020 Lancaster, PA 17604-3020 Phone: 717-397-4701 <a href="http://www.usboiler.net/">www.usboiler.net</a>.
August 29, 2011
Subject: Flood Damaged Boilers
The unfortunate situation and questions relating to flooded boilers and heating equipment arises whenever major flooding occurs. U.S. Boiler Co. customer service and technical service representatives are often asked what should be done with a flood damaged boiler. It should be noted that flooded boilers present a number of potentially very serious safety issues including, but not limited to, the following items:
• Floodwater may enter a boiler and soften the insulation that surrounds the combustion chamber, causing it to collapse into the chamber.
This causes a very serious safety issue, and under no circumstances should any boiler be operated in this condition.
• Additionally, the silt and contaminants potentially contained in flood- water can be deposited inside boiler controls and safety limits affecting their accuracy and ability to operate. This also can be a very serious safety issue and under no circumstances should any boiler be operated in this condition.
• Also, floodwater can cause unseen damage to the boiler that may cause a safety issue or failure months or even years after the incident. Even components that appear to be unaffected may have sustained damage.
Boilers that are subject to floodwaters or other damage as a result of natural disaster are not covered by U.S. Boiler Company’s limited warranty for residential boilers. Replacing affected components in a flooded boiler leaves much to risk, in addition to being an expensive and difficult procedure. As a result, U.S. Boiler Company strongly recommends that any boiler that has been exposed to flood water be removed and replaced with a new boiler.
Do not operate your boiler if any components have been fully or partially submerged in water until the boiler has been inspected and all affected components or the boiler are replaced by a qualified heating contractor.
Please feel free to contact your local U.S. Boiler Company representative with any additional questions that you may have regarding this issue. Also when replacing a boiler, consider upgrading to a high efficiency boiler manufactured by U.S. Boiler Company for future energy savings.
Nate Warren
Residential Products Manager U.S. Boiler Company, Inc. Lancaster, PA USA
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Ironman
