wet return routing
ChrisJ
ChrisJ Member Posts: 17,069
Ok I'm assuming it doesn't matter but before I pipe my wet return I want some opinions.
I have two wet returns coming in from opposit directions.  Can I pipe it as shown in the top of my picture or will one cause the other not to drain?  One handles a lot more radiators than the other therefore will have a lot more flow.
  • crash2009
    crash2009 Member Posts: 1,478
    I don't think it makes any difference
    which return is first or second from the Hartford.  When they re-did mine I just assumed it didn't matter.  Or the layout of the overhead returns decided where they were going to end up.  Now that you have asked, I went and checked mine, the return with the most EDR is farthest from the Hartford.
    I like the way these returns (in the picture) connect to the Hartford.  Looks kinda like the header on a car.
    Jamie Hall Member Posts: 26,838
    Won't make a bit of difference
    There will be a slight difference in head loss with a T like that, but I do mean small.  Like almost unmeasurable.  So don't worry about it.
