pickup factor
ChrisJ
ChrisJ Member Posts: 17,052
I'm curious whether or not the 1.33 pickup factor assumes uninsulated risers in between floors?
I have risers going from the basement to the second floor and of course they are not insulated and probably won't be for some time if ever.  Should I assume a 1.5 pickup factor for this?  This is a single pipe system.
  • Greg Maxwell
    Greg Maxwell Member Posts: 210
    Pick up
    I think 25% is more than adequate, unless you have something extremely uncommon.
  • BobC
    BobC Member Posts: 5,538
    1.33 might be too much
    I believe the 1.33 assumes nothing is insulated but i could be mistaken. Assuming this is an old house, the sizing of the system may have assumed open windows in the bedrooms during the winter months.
    Dan wrote a pieces a few years back arguing for undersizing (slightly) rather than oversizing boilers. Perhaps someone on the wall can point you to that article.
    Bob
    3PSI gauge
  • BobC
    Thats it!
    thanks for the legwork, that is the one I was thinking of. It makes you think just how large a boiler you really do need.
    Bob
    3PSI gauge
