Baseboard heating element fitting
KME
Member Posts: 4
Can anyone identify this fitting? It's cast bronze, reduces from 3/4" copper to 1/2". The long taper and the pins on the side make me wonder if it's something other than a cast tapered reducer.
Doubtful...
The pins are probably just a part of the casting process that didn't get cleaned off in the sand tumbler. If it were something like a balance valve, there'd be a packing gland and a machined shaft where the pins are located.
ME0 -
"WAD DE HELL IS DAT?"
My vote is that it is a combination expansion-reducing joint. I bet the pin is a part of a length limiting system.0
- 114 Geothermal
