Baseboard heating element fitting
KME
Member Posts: 4
Can anyone identify this fitting? It's cast bronze, reduces from 3/4" copper to 1/2". The long taper and the pins on the side make me wonder if it's something other than a cast tapered reducer.
Doubtful...
The pins are probably just a part of the casting process that didn't get cleaned off in the sand tumbler. If it were something like a balance valve, there'd be a packing gland and a machined shaft where the pins are located.
METhere was an error rendering this rich post.
"WAD DE HELL IS DAT?"
My vote is that it is a combination expansion-reducing joint. I bet the pin is a part of a length limiting system.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
