Boiler Manifold Pressure
Energy_Guy
Member Posts: 1
in Gas Heating
Hello All - I'm reviewing some data on a Miura Boiler nameplate and was wondering if anyone could help clarify some of the information. The boiler uses natural gas as a fuel and lists the following information:
Gas Inlet Pressure: 3-5 PSI
Max Manifold Pressure: 31" WC
Is the manifold pressure the pressure within the combustion chamber? I'm assuming that this pressure is dictated by the boiler fan and any restrictions to the flue gas as it is exiting the boiler, is this correct?
Thanks for the help.
The 3 to 5 PSI
pressure is the pressure required before the gas valve (inlet pressure) the 3.1" W.C. is the outlet pressure required at the outlet of the gas valve. It really has nothing to do directly with combustion chamber pressure. The pressure in the chamber is really draft which is developed by the height of the flue and the temperature difference created. This will determine air flow into the chamber (atmospheric) or if a forced draft then excess air is more controlled and will be less than with atmospheric. Typically 40 to 50% excess air atmospheric 25 to 30% with forced draft. Three things should be measured to ensure correct operation:
1. Stack Temperature 275 degrees net or higher with conventional equipment.
2. O2 (oxygen) 4% to 7% depending on system
3. Carbon monoxide under 100 PPM air free
Those along with a draft of -.01, -.02, -.03 is satisfactory.
I am not familiar with the Miura Boiler is it a Mod/Con unit? If so it probably operates with a negative pressure gas valve???0 -
Well Miura is a Japanese
boiler is yours steam or hot water? These are commercial boilers so I would have to look at the specifications to be accurate on any more information.0 -
Q?: 3 to 5 psi???
Something is wrong with that number. Chances are there is a decimal point somewhere in that #. 3 to 5 will blow out that regulator on the boiler.
What do ya think Tim?
Mike T.0 -
This is a large
industrial boiler and some of them have pounds pressure feed to them.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
