Buffer tank piping diagram
Leo_G
Member Posts: 89
Hey anyone out there have a schematic of the piping layout for a top supply to system, bottom return, side supply from boiler, three hole buffer tank application?
Thanx in advance
Leo G
Thanx in advance
Leo G
by 3 port
do you mean a port mid way up on the side of the tank? Or about 10- 12" up , which is common on DHW storage vessels.
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Hot rod
I have been perusing the B-W storage tanks as one choice, but would prefer to find something with no dip tubes, so one opening on the top (system out), one at the bottom (boiler return and maybe the system return on a tee to this pipe?) and one I would hazard to guess within the top third of the tank on the side (boiler supply). Does this sound feasible?0 -
there are a few
brands of buffer specific tanks on the market. I'm most familiar with this one. It has seven 2" ports scattered around the tank and a few 3/4" on top, anode rods can be added here if the tank is used for DHW, and a 3/4 drain cock.
It can be used as a buffer with the ability to pipe in at the mid tank port. It also can serve as a super sized hydro separator.
- 114 Geothermal
