Need a little help
Joe80
Joe80 Member Posts: 2
i have a lennox hs29-411 and it took a dump. Now I found a hs25-311, but not sure if it will swap over without a problem?
  • Ironman
    Ironman Member Posts: 7,871
    Not The Same
    The HS29-411 is a 3ton and the HS25-311 is 2.5 ton. The HS29 is also a higher SEER unit.
    I would not recommend installing the HS25-311 in place of the HS29-411.
    Bob Boan
