Radiant Slab Sensor
MTR
MTR Member Posts: 8
Does a radiant slab sensor have to be embedded directly into the concrete?  I was planning on running a 1/2" pex line down the wall and into the slab for the sensor wiring.  Was wondering if I could cap the end of the pex and put the sensor in the tubing itself.  Figuring in the future if it went bad, I could pull it out and replace.
  • Terry O
    Terry O Member Posts: 67
    Makes sense....
    and actually, that's what we've always recommended.
    Terry O
