Radiant Slab Sensor
MTR
Member Posts: 8
Does a radiant slab sensor have to be embedded directly into the concrete? I was planning on running a 1/2" pex line down the wall and into the slab for the sensor wiring. Was wondering if I could cap the end of the pex and put the sensor in the tubing itself. Figuring in the future if it went bad, I could pull it out and replace.
Makes sense....
and actually, that's what we've always recommended.Terry O0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
