Why shoud hot water boilers not be oversized?
Tom Andrews
Tom Andrews Member Posts: 5
Hello,
I was wanting some information on why a hot water boiler should not be oversized.  Specifically, I am interested in the efficiency issues.  Is there data available regarding fuel consumption and short cycling?
Thanks.
Tom
  • CMadatMe
    CMadatMe Member Posts: 3,086
    Common Sense
    Don't mean you don't have any but thing about it. If I need 60K btu's and I install a boiler that is 100K, which by the way is only needed on my design days, where does the other 40K go that I paid to burn? Those extra btus wasted get larger as the days get above the design temp.
    Short cycling also causes more maintenace and service issues. Bigger is not better.
  • NRT_Rob
    NRT_Rob Member Posts: 1,013
    If you're interesting
    there are commercial white papers that reference 50% efficiency losses from short cycling. ORNL's domestic hot water testing from boilers shows 30% efficiency in the summer on cast iron and high 50's/low 60's even from mod/cons... that's primarily because of worst-case cycling losses (all residual heat is wasted).
    on top of that you have lifecycle costs to consider.
    Rob Brown
    Designer for Rockport Mechanical
    in beautiful Rockport Maine.
  • Tom Andrews
    Where to get papers?
    Thanks - that's what I was interested in - actual published data.
    Do you know where I might access some of the commercial white papers?  Anyone else beside ORNL?  Appreciate the direction.  Thanks
  • NRT_Rob
    here's one
    that you might like
    Rob Brown
  • Tom Andrews
    Perfect
    That was perfect.  Thanks very much Rob
    Tom
  • NRT_Rob
    sure
    fun read. it's for commercial boilers, so I would hesitate to translate it directly to residential scale boilers. but it establishes the fact that it matters, at least.
    I can't wait for datalogging tech to sink in price a bit more so fuel use vs heat delivered can be compared on more systems!!
    Rob Brown
  • Big Ed_4
    Big Ed_4 Member Posts: 3,364
    Sized for the largest load ...
    Which in most residential is domestic hot water ...if the boiler is used for it as well as heat..
