Forced h.w. zone off new steam boiler????
Paulien
Member Posts: 7
Best way to set this up w/ a NEW steam boiler? Pics. show former boiler & the zone that was existing... Any feedback from any installers out there that have had successful results?! Thanks
Like everything
It depends. What will your new steam system be? If you go with the new Burnham Megasteam they have a specific way to pipe a HW zone off their boiler. Just simply follow their instructions and you will be fine.
Are you having the install done and if so are they familiar with steam?0 -
Here is What You're Looking For
http://www.heatinghelp.com/article/17/Hot-Water/76/Condensate-Hot-Water-HeatingBob Boan
Thanks for the tips,,have installed many a steam boiler,but never a h.w. zone off it..0 -
Staying with oil ?
Best way in my opinion is to pressurize the zone with a coil .
Another option is a heat exchanger .
If the zone is lower than the boiler , I'd connect it directly to it . Gotta use a relay and aquastat to make sure the boiler don't steam if the water zone calls alone .0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
