Main Vent Calculation
I have no main vents in my single pipe steam system.  I have two mains - a 45 ft run and a 24 ft run.  I've removed sheetrock and have found a spot for the main vents, but would like some assistance on how to calculate the optimal number of main vents.
For a 45 and 24 ft run (1 3/4" pipe), how many Gorton #2s would you recommend on each main?
Thanks for the help.
    Steamhead Member Posts: 15,988
    I'd use a Gorton #1 on the short main
    and a #2 on the longer one.
    If you want to use all #2s, use one on the short main and two on the long one.
    Consulting
  • jamesylove
    jamesylove Member Posts: 6
    Tapping into main
    Any recommendations on drilling/tapping into the main?  I do not have room to insert a tee, so I'll have to tap it.  Is a 1/2" tap sufficient?
    Yup
    that'll work fine. Just make sure you angle the tap up slightly from horizontal. This will angle the pipe upward a bit so water won't collect in it.
    Consulting
