Main Vent Calculation
jamesylove
Member Posts: 6
I have no main vents in my single pipe steam system. I have two mains - a 45 ft run and a 24 ft run. I've removed sheetrock and have found a spot for the main vents, but would like some assistance on how to calculate the optimal number of main vents.
For a 45 and 24 ft run (1 3/4" pipe), how many Gorton #2s would you recommend on each main?
Thanks for the help.
I'd use a Gorton #1 on the short main
and a #2 on the longer one.
If you want to use all #2s, use one on the short main and two on the long one.All Steamed Up, Inc.
Consulting0 -
Tapping into main
Any recommendations on drilling/tapping into the main? I do not have room to insert a tee, so I'll have to tap it. Is a 1/2" tap sufficient?0 -
Yup
that'll work fine. Just make sure you angle the tap up slightly from horizontal. This will angle the pipe upward a bit so water won't collect in it.All Steamed Up, Inc.
Consulting0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
