Steam Fittings
wmgino
Member Posts: 1
I am wondering if it is a must to use steam fitting (cast) over black pipe fittings. The reason for this question is we are having this discussion at work and I have always been told you must use steam fitting, I am also being told that supply houses are only selling black iron fittings now for steam not cast fitting.I need this dilema put to rest please help and if possible be specific so this discussion at work can go to bed.Thanks for your assistance.
it is not necessary
to use cast verse mallable iron...but some day, you kids may want to remove one of those fittings, and it will be easier to get it off if its cast as opposed to mallable..otherwise they are both iron.gwgillplumbingandheating.com
I often need to use malleable fittings
You can only install what you can buy. The excuse my former wholesaler gave me as to the lack of cast iron fittings was "everyone owns a sawzall now" . Lame excuse far as I am concerned. They work but check local codes. I have heard in NYC cast or nothing but as I do not work in the City I have not confirmed this.Cost is what you spend , value is what you get.
cell # 413-841-6726
cast iron
One of the reasons that I have heard for the use of cast iron is that the walls are thicker, so they can take more of a thermal beating. I was also told that it is therefore most important to get cast iron in the risers and header and the mains, but less critical farther out.0 -
Fittings
Check the data sheets from the manufactures, they are both rated for steam, malleable has a higher rating that cast iron and tends to be more readily available.0
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
