Monoflo
Plumb_Bob
Member Posts: 1
I have a small commercial building that I am putting in a new cast iron boiler. It is an old monoflo system with a two inch steel pipe main and 3/4 branches to registers. (Fin tube cabinet type). It also has an add on in the back of the building with a one pipe 1 inch line... The supply house designers said the two inch line is over sized and decreased the boiler loop to 1-1/2" and the zone comes off 1-1/4 to the supply to the two inch monoflo side of the system. Just wondering if this will be adequate.
BTU's?
What is the output of the boiler and what is the EDR of the loop?Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 772 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
- 19 Recall Announcements
