Reasons why my pressure relief valve leaks?
I have a Weil-Mcclain EGH steam boiler and the ASME pressure relief valve (rated 15psi) just started leaking. The pressure relief valve in only 2 years old. The pressure gauge reads 1 psi.
Any suggestions? Thanks!
  • Jean-David Beyer
    edited January 2011
    I am just a homeowner.
    It is remotely possible that your pressure relief valve is defective and needs to be replaced.
    There are a few more possibilities..
    This is, however, a life-safety problem, so I suggest getting a suitable hot water heating professional in there to see what is going on and to fix it.
  • Steam?
    Really?  And the pressure relief is leaking?
    Turn that puppy off and get a professional in there to find out why.  The pressure relief valve is the last line of defence before truly catastrophic problems can happen, and should never, ever even crack a drip unless all the other safety devices on a steam boiler have failed.
    Not to mention -- if the possibility of the boiler blowing isn't enough -- if the pressure is really that high, you stand a good chance of damaging any vents or traps in the system.
  • If in doubt
    go with Jaimie's advice and turn it off.
    Frequently, weeping can occur with the tendency to "test" the relief valve under pressure, OR you may have had a runaway condition you were not aware of.  Does your gauge go to zero? If damaged, that may be a sign of an incident.
    Either of those can loosen a bit of scale or rust during the discharge which comes to rest on the seat, enough to cause a leak. It may be that simple, but again, it may not. Replacing the valve (and conducting discharge piping downward to a safe place), is short money.
    Speaking of pressure gauges, there is a nice part in the MA large boiler code which is out of ASME, I believe. It requires a tee and petcock or isolation valve just below the primary pressure gauge and above the siphon/pigtail. The purpose is to allow you to hook up a temporary gauge of known accuracy and condition, to check the "house gauge". I am not sure if the residential code requires it, but I am going to make it a standard detail. Short money and it can answer a few of your questions now. But not with a hot boiler.
    -Ernie White, my Dad
