Honeywell Thermostats
Hi All,
I am considering a replacement thermostat because the previous owners installed one that only has 6 cycles per hour (way too many for 1-pipe steam). I don't need anything complicated and have narrowed it down to two models. They are both Honeywell and the model numbers are RTH7600 or RTH2310. I like both because they are small and both claim to support steam systems. The strange thing is, the RTH7600 'Steam' setting is 1 cycle per hour but the RTH2310 'Steam' setting is 2 cycles per hour.
My question is will I really see a difference between 1 cycle per hour and 2 cycles per hour on a steam system? One last piece of information is that I know my boiler is oversized for the house because the pro that I had come and review the system said my boiler is '3 sizes too big for the house.
TIA,
Mark
    Jamie Hall Member Posts: 26,843
    Actually,
    you probably would.  I'd be inclined to go with the 7600...
    If the boiler really is much too big, it will cycle on pressure with either one -- won't make any difference, really.  But keep the pressure low...
