Relay with delay needed
BrianCNY
Member Posts: 26
Greetings
I have a relay that I need to work exactly as it does now, except I need a delay of 30 seconds (or up to a minute would work).
I attached the specs of the current relay.
Does anyone know what part# I would need and perhaps an online source?
Thanks . . . . Brian
Delay?
Delay on make or delay on break?
If on make, why not use an ICM 2 wire time delay in series with the coil?Bob Boan
Delay on Break
Thanks for your suggestion Bob.
I should have specified, delay on break.
Brian0 -
Delay on Break
Will this work for you Brian?
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=delay+on+break+relay&op=search&Ntt=delay+on+break+relay&N=0&sst=subset8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
delay on break
I use Mar's 32392 SS Delay on Break Timer I use them for multiple applications. Works from 19 to 240 VAC; 6 sec. to 5 min. if you need more time put them in series.
I hope this helps
MERRY CHRISTMAS
MC0
