Changing 5 ft of 1 Inch copper to 3/4 inch pex
tpost
Member Posts: 1
in Oil Heating
Can i change 5 ft of 1 inch copper out to 3/4 inch pex to move the pipe for visual reasons? I have a loop system and would like to move a pipe that is running over head thru my finished basement. it is about 5 ft long and at the beginning of my downstairs heating zone.
Copper to PEX
You can do whatever you want. No one is watching.
However, pipes increase as do their squares.
That neans that it takes 4, 1" pipes to equal a 2" pipe. And it takes 4, 3/4" pipes to equal a 1 1/2" pipe.
And I think that 3/4" PEX has a smaller inside diameter than 3/4" copper tube.0 -
pipe size
Ice is right. You get about half the capacity if you use 3/4". Why not use 1"? If you don't have a 1" pex tool, you can use "SharkBite" fittings that transition directly to copper. Make sure that you use Oxygen Barrier pex, not the regular pex that is used for plumbing.
If you have a Monoflo system, then chocking down the loop to 3/4" is really not a good idea. You also better know how to purge and bleed the air out or you'll be having alot of hydronic head aches.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
