Gravity fed water system?
mrichard
mrichard Member Posts: 27
Had a service call the other day for a boiler service(clean etc..) noticed there was no circ pump and seemed as though the pressure was very low,yet everything was working fine? Date on it was 1964,obviously talked them about a new system.
Instead of possibly screwing something up,I tried to seek more info before adding more water,so I removed burner assembly and clean etc..go through check list.
Can anyone explain operating pressure and basically how this system works?
Thanks for any help
  • Ironman
    Ironman Member Posts: 7,858
    Gravity System
    Go to the "Systems" tab above. Then click on "Hot Water", then click on "Gravity Systems".
    Bob Boan
