burnham oil boiler running 15 seconds
hard
Member Posts: 4
in Oil Heating
then shutting off. Any clues what might be wrong?
poor info
this is another example of poor information ,no history of service, make of burner,from this tiny bit of info sounds like a bad cad eye, but again..........0 -
Stack relay with honeywell aquastat
will restart when reset is pushed and then again cuts off in 15 seconds? What to expect when serviceman arrives?0 -
just watch
how he diagnoses the problem,step by step.with a stack relay now we are talking of a possible dead ignitor or clugged nozzle ,you still did not tell us when was your last service on the unit,keep up posted.0 -
The boiler fires and the flue gets hot
to the touch. Could it still be a dead ignitor or a clogged nozzle? I just dont want to pay for parts I dont need. Will for sure share the fix(if he gets it)0 -
you are right
if the unit fires up you definetely do not have a bad ignitor or plugged nozzle.you may have a stack relay that is going bad or burner motor going bad,if you are lucky to get an experienced oil mechanic he wont be changing parts and diagnose the right way.0 -
stack relay
if you have a chance let us have the number in the back of the stack relay thank you.0 -
It was the cad cell
Fellow showed up smelling of liquor, and showing holiday cheer. Took it apart changed the cad cell, let me look at the old one. It only cost me $98. I was very very happy to have heat and someone who did not tell me I needed a new one. Which I could figure that out for myself. Thank you for all your help.0 -
you welcome
i am glad it worked out, the technician wasn't drunk enough.....0
- 120 Geothermal
- 169 Indoor-Air Quality
