Seeking knowledgeable 2 pipe steam heat service
Bodie
Bodie Member Posts: 1
We recently moved into our home that has a 2 pipe steam heat system.  We are seeking someone in the Fairfield, Ct. area, who  knows what they are doing, when it comes to this kind of a system.  We did work on the house prior to moving in, but the contractor's plumber doesn't seem to be up to speed on our system.
    Jamie Hall Member Posts: 27,403
    Did you try...
    the Find a Contractor?  Look under State, not zip, and try New York as well as Connecticut.  If that doesn't work, take a look at Charlie in WMass -- I know he has worked in your area, on occasion, and I can vouch for the quality of both his knowledge and workmanship.
