Tank less hot water information... Important......
Gs1
Member Posts: 1
Can someone please tell me, how come you should not use a tankless hot water heater to heat your home in a closed loop system...... noritz recommends to only use their line of hydronic tankless boilers in a closed loop system..... Can you please tell me why you are not supposed to use a regular tankless heater in a closed loop system to heat your house... A lot of other companies also do not recommend using the regular heaters for closed loop system.......... why.. Gs1
Here's a link to a recent thread
http://www.heatinghelp.com/forum-thread/132410/Exterior-commercial-Rinnai-to-replace-existing-old-boiler#p1203671There was an error rendering this rich post.
The Simple Answer
It's not made to do it. If a tankless could take the place of a boiler, then they'd stop making boilers!
The problem is that a lot of folks become blinded to the obvious truth because their greed overrides common sense.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
