Control numbers
Tim McElwain
Tim McElwain Member Posts: 4,657
of ignition modules, gas valves etc are a big help if you can give them here concerning gas systems. It makes it much easier for you and me if I can specifically know what controls you are dealing with. Boiler and Furnace Model and serial numbers also help but control info is very important.
  • Tim McElwain
    I bumped this back
    up in hopes that it will prompt techs to get numbers so I can quickly help you. I do not know what every boiler and furnace has for controls so the numbers can quickly get diagnostic results from me and others who are here to help out.
    As for homeowners I would encourage you also t get numbers as it will help us to assist you with your problems.
