Swing Joints
Logan
Member Posts: 1
in Gas Heating
How many elbos in a proper swing joint and is the length of the nipples important
three
length depends on pipe diameter.Cost is what you spend , value is what you get.
cell # 413-841-6726
swing joints - no easy answer
No easy answer, 3 elbow swing joint is considered the "cats pajamas" for entering a building from a riser from the ground, if it is piped correctly. I have seen more, but less won't do, unless it is a sizzor joint, which is for a different application and then you could still use 4 or more there, depending. If it were easy, they wouldn't have paid me $millions$ over the years to do it right...
Length of nipples depends on pipe size, but typically 4 to 6 inches (depending).0
- 84.3K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3K Oil Heating
- 57 Pipe Deterioration
- 795 Plumbing
- 5.4K Radiant Heating
- 371 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
