Honeywell L8148E Aquastat relay
John B_2
Member Posts: 46
can I run boiler below 180 with this??? The spin wheel only goes down to 180.
John
John
this is a cold start control that has a 180 degree min hi limit setting. Go digital with it0 -
Can you recommend a digital one
One that will be used with ODR.
John0 -
Try This
.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 120 Geothermal
