tubing kink
Karl_4
Karl_4 Member Posts: 11
Has anyone had to find a kink in a loop that is already in concrete? I tried the shoving a wire to the kink and using a wiring tracer to find where it stops but the tracer instrument is not precise.
  • tim smith
    tim smith Member Posts: 2,886
    That will be interesting to find
    Worst case, xray slab to find. Maybe run temp up a bit if a little flow will go through kink and use IR camera and trace until you find the cool spot which I would think would show up if a little flow goes through. Tim
